saj3417
Feb 27, 2020Aspirant
***MR1100-NSA100 : FYI T-Mobile customers ***
This is regarding tech support case number: 42350449 I purchased an unlocked Netgear MR1100-100NAS late December 2019, that had some weird battery charging issues but nothing to be concerned abou...
- Mar 02, 2020
I have a post liniking to a way to force the downgrade if you are a bit tech savy it is easy enough check my post about 12.06.11 burning through battery, and you will find a link to a post detailing how to forcce downgrade.
BlightedTalon
Mar 02, 2020Star
- saj3417Mar 03, 2020Aspirant
I had some issues finding FDT.EXE, but once I got pass that hurdle, I was able to downgrade the router to release 12.05.05 and BOOM!! T-Mobile LTE service restored. Thanks, I really appreciate your help.
This is my last Netgear product purchase. I will never purchase or recommend Netgear to anyone based on their service and support.
-Thanks !!- JohnPengMar 05, 2020NETGEAR Expert
-Thanks !!When you say your T-Mobile service is restored, what do you mean by that? Was your T-Mobile service was blocked or your data connection was not stable?
Thanks
- BlightedTalonMar 05, 2020Star
I cannot speak for them but I can confirm for me, that the latest update did make my connection very unstable and the modem was constantly hopping LTE bands, and had to join them on 12.05.05 to get an effective working unit, the last two update have had various bugs, some of which I have mentioned in other posts, Extreme battery usuage (even got a new battery), not staying off during charging, Constant band hopping leading to unusable Tmobile LTE connections, and I could continue.
Please as a software negineer myself and have worked as a test engineer in the past. Please spend more time on testing firmwares, as this few last batches of updates have been poorly QA checked. I will likely join this poster in not buying another netgear product if this is the kind of support your team has been put to as a mark of quality...
- RedRaiderMar 14, 2020Aspirant
Good Morning, can you repost the link. When I click on the View Solution it takes me back to the same page. Thank you
