saj3417
Feb 27, 2020Aspirant
***MR1100-NSA100 : FYI T-Mobile customers ***
This is regarding tech support case number: 42350449 I purchased an unlocked Netgear MR1100-100NAS late December 2019, that had some weird battery charging issues but nothing to be concerned abou...
- Mar 02, 2020
I have a post liniking to a way to force the downgrade if you are a bit tech savy it is easy enough check my post about 12.06.11 burning through battery, and you will find a link to a post detailing how to forcce downgrade.
BlightedTalon
Mar 02, 2020Star
RedRaider
Mar 14, 2020Aspirant
Good Morning, can you repost the link. When I click on the View Solution it takes me back to the same page. Thank you
