saj3417
Feb 27, 2020Aspirant
***MR1100-NSA100 : FYI T-Mobile customers ***
This is regarding tech support case number: 42350449 I purchased an unlocked Netgear MR1100-100NAS late December 2019, that had some weird battery charging issues but nothing to be concerned abou...
- Mar 02, 2020
I have a post liniking to a way to force the downgrade if you are a bit tech savy it is easy enough check my post about 12.06.11 burning through battery, and you will find a link to a post detailing how to forcce downgrade.
BlightedTalon
Mar 14, 2020Star
For all those looking for downgrade info please see this post.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/MR1100-Firmware-Update/m-p/1813134/highlight/true#M11066
RedRaider
Mar 14, 2020Aspirant
With the help of JohnPeng, we downgraded my MR1100 to 12.05.05, this did not fix the issue with T-mobile. It definitely appears the issue with no data is on the side of the T-Mobile network and not Netgear. Hopefully T-Mobile will allow the MR1100 to work on their network again soon. Thanks again JohnPeng for your help.
- JohnPengMar 17, 2020NETGEAR Expert
Thanks for the information. Based on our investigation, T-Mobile is not blocking the sevice to M1. You need to get the data plan for mobile hotspot in order to use M1. Customers experiencing disconnection issue on T-Mobile need to contact T-Mobile to update the subcription.
Regards
- RedRaspberryMar 17, 2020Guide
TMobile works fine onmy MR1100 with the AT&T firmware NTG9X50C_12.05.12 ada Consumer Cellular SIM.
Consumer Cellular SIM is T-Mobile MVNO?
Thanks
