saj3417
Feb 27, 2020Aspirant
***MR1100-NSA100 : FYI T-Mobile customers ***
This is regarding tech support case number: 42350449 I purchased an unlocked Netgear MR1100-100NAS late December 2019, that had some weird battery charging issues but nothing to be concerned abou...
- Mar 02, 2020
I have a post liniking to a way to force the downgrade if you are a bit tech savy it is easy enough check my post about 12.06.11 burning through battery, and you will find a link to a post detailing how to forcce downgrade.
RedRaider
Mar 14, 2020Aspirant
With the help of JohnPeng, we downgraded my MR1100 to 12.05.05, this did not fix the issue with T-mobile. It definitely appears the issue with no data is on the side of the T-Mobile network and not Netgear. Hopefully T-Mobile will allow the MR1100 to work on their network again soon. Thanks again JohnPeng for your help.
JohnPeng
Mar 17, 2020NETGEAR Expert
Thanks for the information. Based on our investigation, T-Mobile is not blocking the sevice to M1. You need to get the data plan for mobile hotspot in order to use M1. Customers experiencing disconnection issue on T-Mobile need to contact T-Mobile to update the subcription.
Regards
- RedRaspberryMar 17, 2020Guide
TMobile works fine onmy MR1100 with the AT&T firmware NTG9X50C_12.05.12 ada Consumer Cellular SIM.
- JohnPengMar 17, 2020NETGEAR Expert
Consumer Cellular SIM is T-Mobile MVNO?
Thanks
- BlightedTalonMar 17, 2020StarConsumer Cellular uses AT&T and T-Mobile for it's MVNO network.
