dec1000
Mar 13, 2020Star
MR1100 on T-Mobile
I had service on a ATT tablet plan and had good speeds. With ATT discontinuing the plans I have now got a plan with T-Mobile. I have good signal but the speeds are terrible compared to what I got wit...
JohnPeng
Mar 13, 2020NETGEAR Expert
As we know T-Mobile changed their plan for M1. If you are using a plan for Tablet or phone, it will not work on M1. You have to use the plan for Mobile Hotspot.
Thanks
dec1000
Mar 13, 2020Star
It is a plan that OTR Mobile is selling that is unlimited internet. It is working with the APN set to Broadband, but the speeds are low. I have a good to excellent on LTE Band 12 and should be getting better speeds. I had a plan with the on ATT that was averaging from 70-100 and they discontinued the plan so now I have to go with T-Mobile and am getting speeds from 5-10. Big difference. It is a new plan to them so they are not much help.
- danman9Mar 14, 2020TutorWhat is the apn settings for broadband?
- dec1000Mar 14, 2020Star
APN Name: T-Mobile
APN: broadband
PDP: IPV4V6
PDP Roaming: None
Authentication: None
- jmatsonMar 21, 2020Aspirant
Did u have to wait for a Unlock code? i put the Sim in and still have no internet. I have chaned the APN Settings and nothing. and OTR is so freaking slow. I can't even get internet on the ATT side anymore
