dec1000
Mar 13, 2020Star
MR1100 on T-Mobile
I had service on a ATT tablet plan and had good speeds. With ATT discontinuing the plans I have now got a plan with T-Mobile. I have good signal but the speeds are terrible compared to what I got wit...
FatStanley
May 13, 2020Aspirant
The cards you get at retail stores are limited. Can't get more than a couple of days of good use out of them.
Neverthrottled is unlimited. I stream all month long and use about 1TB, no issues.
Zach03
May 17, 2020Aspirant
I have otr with Tmobile. Lost service Friday was told Tmobile issued new blacklist imei. Went through all the steps with otr to no avail. They said its nation wide and they are trying to resolve it.
- dec1000May 17, 2020Star
Why do you keep putting up with them? There are plenty of other companies you can get service from. ATT cut them off so they went to TMobile. Now they are having issues with TMobile so they are trying to get people on some new deal with ATT. There is no reason to believe it is going to get better,
- Jim1348May 25, 2020Aspirant
Here is my experience today.
-I bought a line of T-Mobile service today.
-When I use the T-Mobile SIM card in a Sonim XP8 I get fast speeds. For example, 141 Mbps down and 38.3 Mbps up.
-When I use the T-Mobile SIM card in an unlocked Netgear Nighthawk MR1100, my speeds are much slower. For example, 8 Mbps down and 2 Mbps up.
-I suspect that my settings are wrong. What should I change?
-Current APN Settings:
APN Name: T-Mobile
APN: broadband
PDP: IPV4V6
Authentication: None
- JohnPengMay 26, 2020NETGEAR Expert
Please try the following T-Mobile APN:
- Name: T-Mobile US LTE
- APN: fast.t-mobile.com
