LB_BabyBoi
Jun 17, 2019Tutor
MR1100 Overheating?
Is your MR110 Overheating? So i have read that the MR1100 has been overheating after the latest update to some. I have Solved what i think maybe the Issue.. in order for me to be forsure if what...
Shanem21
Aug 28, 2019Aspirant
Mine stops charging with a battery heat mode warning. I have a 32G sd card installed but I'm not useing the usb A port for anything. Charging with the C port. What have you found?
