LB_BabyBoi
Jun 17, 2019Tutor
MR1100 Overheating?
Is your MR110 Overheating? So i have read that the MR1100 has been overheating after the latest update to some. I have Solved what i think maybe the Issue.. in order for me to be forsure if what...
LB_BabyBoi
Nov 02, 2019Tutor
when using the mr1100 with a external memory it seems to overheat faster.. what i have done is under settings trying and reduce the amount of push power.. iv turned brightness to low.. have the Blinking LED inducator off. if used with power outlet it is best to keep back cover off.. and the last thing is to trun Dual band. other then that power down and just let it charge with no use of the hotspot.. hope that helps
Harold55
Nov 14, 2019Aspirant
@myprepaidcenter wrote:when using the mr1100 with a external memory it seems to overheat faster.. what i have done is under settings trying and reduce the amount of push power.. iv turned brightness to low.. have the Blinking LED inducator off. if used with power outlet it is best to keep back cover off.. and the last thing is to trun Dual band. other then that power down and just let it charge with no use of the hotspot.. hope that helps
The M1 was able to charge up the battery to 100% while being in use, and kept the battery fully charged the whole time. This has never worked before, it only did now after upgrading to the new firmware NTG9X50C_12.06.07.00. So I can confirm that NTG9X50C_12.06.07.00 is a big big step forward for the M1.
