Marth286
Mar 10, 2021Aspirant
MR1100 Port Forwarding
Hello Netgear Community, I am trying to do some Port Forwarding to achieve an OPENED NAT for my Switch console that is connected to the router. To do so I must enable Port Forwarding on static...
michaelkenward
Mar 11, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Cable Modems, Routers and DSL Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I will ask the Netgear moderator to move your message.
- Marth286Mar 11, 2021Aspirant
Thank you, Yes please do such move.
Cheers
