ianobrien43
Aug 26, 2019Follower
MR1100 powered only by 12VDC
I have an ATT MR1100 mobile LTE router. I need to be able to power the unit without the battery via the USBC cable connected to a 12VDC USB port in my houseboat. My USB 12VDC port says it's rated for...
W1lliam
Sep 07, 2019Virtuoso
You probably can't take that 12VDC onto M1 USB-C port, need another charger supporting QC, 2.0/3.0, and you can then have a change cable plugged inot M1's USB-C port, make sure you buy a good quality of the charge cable (USB to Type-C, or Type-C to Type-C, depends on your charger) as M1's power design is very sensitive, improper cable would cause stability problem.
