SeánB
May 24, 2020Aspirant
MR1100 primary 4G band problem with distant 4G+ site
I am in a rural part of Ireland where I pick up a 4G+ site quite far away with the help of an outdoor MIMO antenna. The cell operates on bands 20, 3 and 1 and my previous LTE Cat 6 router worked fin...
Blanca_O
May 31, 2020NETGEAR Employee Retired
Hi SeánB
Welcome to NETGEAR Community!
May we please know the device SKU (MR1100-xxxxx)?
The following KB links will show list of supported bands:
What cellular bands are supported by MR1100 Nighthawk M1 Mobile Router?
Blanca
Community Team
- SeánBMay 31, 2020Aspirant
Thanks for replying. The device SKU printed at the bottom is MR1100-100EUS and the H/W is 1.0.
Since posting above, it received a firmware update, current version is NTG9X50C_12.06.12.00. The issue remains in this verson.
My provider operates on bands 1, 3 and 20, which that cellular bands article shows this covers. Due to my distance from the cell tower, I can use band 20 as the primary band (transmit & receive) and bands 1 and 3 for carrier aggregation (receive only).
From further testing, the M1 seems to switch to band 1 or 3 when the RSRP of either band is around -108dBm or less negative. As a crude workaround, I attached extension leads to the antenna leads to deliberately attenuate the signal. It now stays on band 20 longer while still being able to use the (now very weak) signal on bands 1 and 3 for carrier aggregation.
Even with the signal weakened, it still occasionally jumps to band 3 as the RSRP fluctuates up/down depending on the weather, in which case I have go into the web interface to toggle the mode between band 20 and 'LTE ALL' to restore Internet access. It appears that the router is not detecting that the cell is not allowing it transmit to it on bands 1 or 3 and in turn getting stuck trying.
- W1lliamJun 04, 2020Virtuoso
Possible improvement could be getting customized LTE antenna designed for B20 (below 1700MHz is fine), which can improve B20 signal quality then you probably can stay on B20 as main band. Plug into TS-9 ports should work.
- JohnPengJun 05, 2020NETGEAR Expert
I agreed with William. You may have to get a better external antenna or adjust your antenna location to see whether the device can pick up better signal on B20. It is just tracky location for the device to work on B1, B3 and B20.
