TyroneSuperNut
Mar 15, 2020Aspirant
Mr1100 questions
Hello. I am interested in the MR1100. I have a few questions. *What kind of speeds can i expect in one of the worst states for service coverage? My sprint network gets around 15 mbps download. *Is...
Lexsteel
Apr 28, 2020Aspirant
Speeds will be very close to mobile speeds unless you provider supports carrier aggregation
*Is the NAT type open? Moderate? Strict? Can you change it?
You can open ports manually
*How long will the battery last if 5 devices are connected?
I get all day battery 20h or so with low power and nothing connected to the ports at the back
*Do i have to worry about over charging the device?
No I leave mine connected 24/7
*Can you do casual games on it? Basically decent ping?
Depends on carrier, if you gaming jitter is the worst problem not ping
My ping in around 50ms but my jitter is 10, meaning 1 pack can take 50 ms the next could be 40ms and the one after could be about 60
Try tethering from your phone first
