Truckstoptv
Aug 10, 2019Aspirant
Mr1100 reboot constant
Has Netgear ever actually found a solution to the constant reboot on mr1100 unit? I have tried multiple solutions on this page and all over Google yet nothing. I have some major issues with two ...
Blanca_O
Sep 04, 2019NETGEAR Employee Retired
Hi Truckstoptv
Where did you purchase these 2 units? Just to confirm, if you will remove the battery then the device works fine. Is that right?
May I request for the following information:
- Exact model number
- Network
- Firmware
- Purchased from
- Battery Part Number
Blanca
Community Team
Truckstoptv
Sep 04, 2019Aspirant
No not correct. With the battery in, it just freezes vs continuously restarting.
Model MR1100-2A1NAS, MR1100-1A1NAS
Network: AT&T, T-Mobile
Firmware: NTG9X50C_12.05.05.00
Purchased through AT&T
Both Batteries 308-10034-01
- Blanca_OOct 10, 2019NETGEAR Employee Retired
Hi, All,
This has been brought up already to engineers and are already aware of the issue. We are working on a fix and it will be pushed out in next couple of weeks.
Blanca
Community Team- WhcivOct 10, 2019Tutor
Thank you for the update. We look forward to a fix. This issue makes our Netgear hotspot useless in many areas.
- Blanca_OOct 24, 2019NETGEAR Employee Retired
Hi, All,
A new firmware was released for MR1100-100NAS and MR1100-100EUS. Kindly check your devices and update the firmware.
Release notes:
https://kb.netgear.com/000061333/MR1100-Firmware-Version-NTG9x50C-12-06-07-00-00
Blanca
Community Team- rsanagustinJan 25, 2020AspirantI purchased my MR1100-1A1NAS about 2/3 MONTHS AGO AND IM HAVING THE SAME ISSUE WITH CONSTANT REBOOT & BATTERY NOT CHARGING.
IS THIS FIRMWARE UPGRADE FOR THE MODEL I HAVE OR IS IT ONLY FOR THE MR1100-NAS?
