usmcordie
Oct 17, 2018Tutor
MR1100 Screen Lock and Password security
Hello,
I have the
MR1100 – Nighthawk LTE Mobile Hotspot Router (AT&T) that I use for travel and work connectivity.
My last Mifi type device allowed me to lock the screen out with a pin...
- Oct 20, 2018
Here you go.
1) Connect to the web management interface (connect device to wifi network, use browser to go to admin page of hotspot e.g. 192.168.1.1
2) Go to "Setup", "Wireless"
3) Scroll to bottom. Check or uncheck "Display info on LCD"
JSchnee21
Oct 19, 2018Virtuoso
Are you referring to the Wireless SSID and password for your various hotspot wifi networks? I'm pretty sure that there is a configuration setting (not sure if it is in the mobile app or only the web config interface) whereby you can choose to have these not be displayed on the LCD.
Though I cannot seem to find it in the manual right now.
https://www.att.com/ecms/dam/att/devicesupport/5000-5499/5189/NetgearMR1100-QSG.pdf
I don't have the device in front of me, right now.
usmcordie
Oct 19, 2018Tutor
I will look again... thank you!
- JSchnee21Oct 20, 2018Virtuoso
Here you go.
