bucometa
Feb 02, 2022Aspirant
MR1100 SE REINICIA CONSTANTEMENTE
Buenos días. Uso mi MR1100 para vigilancia webcam y lo tengo encendido las 24horas del día. Lo tengo sin batería y conectado a un transformador usb. El problema que veo es que cada cierto tiempo (alg...
Feb 02, 2022Guru - Experienced User
In inglese per favore
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
