bucometa
Feb 02, 2022Aspirant
MR1100 SE REINICIA CONSTANTEMENTE
Buenos días. Uso mi MR1100 para vigilancia webcam y lo tengo encendido las 24horas del día. Lo tengo sin batería y conectado a un transformador usb. El problema que veo es que cada cierto tiempo (alg...
bucometa
Good morning. I use my MR1100 for webcam surveillance and I have it on 24 hours a day. I have it without battery and connected to a usb transformer. The problem I see is that from time to time (a few minutes) the MR1100 restarts itself, I have already changed the cable and the transformer and it keeps resetting itself... what can happen to me?
Thank you in advance.
Feb 02, 2022Guru - Experienced User
Does the resets or restarts stop if you don't use the USB transformer and web cam surveillance?
- JohnPengFeb 02, 2022NETGEAR Expert
In this case, please see whether use battery can help with the issue. MR1100 is an old model and the control chip used in battery has slow response to sudden power boost and can cause the device to restart when using in no battery mode.
The device has implemented charging protection for 7/24 plug in with battery. The battery power will redeuce to 50% capacity when using in this way after 3 days. If you see the battery can't be fully charged, this is normal.
Thanks
