bucometa
Feb 02, 2022Aspirant
MR1100 SE REINICIA CONSTANTEMENTE
Buenos días. Uso mi MR1100 para vigilancia webcam y lo tengo encendido las 24horas del día. Lo tengo sin batería y conectado a un transformador usb. El problema que veo es que cada cierto tiempo (alg...
hajoga4863
Feb 03, 2022Aspirant
Hello. I utilize my MR1100 for webcam observation and I have it on 24 hours per day. I have it without battery and associated with a usb transformer. The issue I see is that every once in a while (a couple of moments) the MR1100 restarts itself, I have effectively changed the link and the transformer and it continues resetting itself... what can befall me?
Much thanks to you ahead of time.
Model: MR1100|Nighthawk M1 Mobile Router
