Splattoramus
Jul 15, 2020Aspirant
MR1100 set Data Cycle on PC
I have a Netgear MR1100 that is using AT&T SIM to connect to cellular service. Strangely, the SIM keep insisting that my billing cycle starts on the 1st of each month. Unfortunately, this is incorr...
icaruspony
Jul 25, 2020Luminary
The MR1100's IP is 192.168.1.1.
Assuming your other router has a different LAN subnet (not 192.168.1.x), then you can just type http://192.168.1.1 into a web browser (even in passthrough mode, because the MR1100 will intercept upstream packets destined for its own subnet).
But if you have a duplicate subnet, your other router will not forward this because of the conflict. If that is the case, you should change your other router's network to 192.168.0.x or 192.168.2.x or something different.
- SplattoramusJul 26, 2020Aspirant
Thanks for the reply icaruspony
That certaily gets me to the Admin console for the MR1100...the problem is that I cannot find a way to edit/modify the the Start/End dates on the modem using my PC. It seems to be simple using the Netgear App, as long as the modem is not in passthrough...but I can't seem to find how to make it work using a PC at all. Any ideas on that?
- icarusponyJul 26, 2020LuminaryThe app is using broadcast (to the same subnet) instead of routing. The app wants to connect to the hotspot via wifi to be on the same subnet, but wifi is disabled in IP Passthrough mode.
- SplattoramusJul 27, 2020Aspirant
Yup, saw that...which is why I was originally posting. :) The fact that I would have to take my entire network offline to turn off IP Passthrough, just to set my data reset dates, seems pretty absurd. I was really hoping it was something stupid on my part like a browser add-on, or a special sequence of keys to unlock true admin mode, or a special spot on the main screeen to get into "Developer's Mode" to unhide that feature. I have seen a lot of that in years past, and have been on projects at work where we did those. I am just not seeing anything like that for this modem, and hoped that someone in Netgear would actually respond with ideas.
