PiD_Media
Mar 19, 2019Tutor
MR1100,.. Telstra firmware to full firmware ??
First Post Question Time ! ;) I have a Nighthawk MR1100, the Telstra version sold here in Oz. When reading through the manual, it appears the only difference in the firmware is that the Telstra...
PiD_Media
Apr 06, 2019Tutor
Bump,...
Does anyone from Netgear read these posts?
Seems the support is spotty at best, and non existant normally.
FCB90
Apr 09, 2019Star
Did You tried tftp maybe?
Other Netgear's routers could be updated this way, but not sure about MR1100.
- PiD_MediaApr 09, 2019Tutor
The update function works fine, I want to know if there's any way to swap from the Telstra Firmware, to the firmware that allows an internal SD card to be used as a regular SMB share.
- PiD_MediaMay 13, 2019Tutor
Bumping.
Does anyone from Netgear even bother to read the posts on the forum?
Customer support from the company seems to be second worst after Atomos.- FCB90Jul 24, 2019Star
No, it's simply the worst.
BTW, try to upload new firmware using "fdt.exe" tool, it's the only alternative way to do it.
Please find more informations on WWW.
