abofayez
Feb 19, 2018Aspirant
MR1100 The operating system can not be updated
welcome everybody I finally got a router. The router works well and the back of the operating system is version 10.05.04. After searching for the update I had an update of 83 Mb. I downloaded the pr...
abofayez
Feb 20, 2018Aspirant
Help us, your experienced people
- UK-basedFeb 21, 2018Luminary
Where did you find the update firmware file? I thought that there were no firmware updates files available on the Netgear site for the MR1100 - it normally auto-updates itself, presumably accessing the firmware on a private Netgear server or your carrier's server.
- abofayezFeb 21, 2018Aspirant
Yeah . The update appears on the Settings \Administration\Firmware Update. But After downloading, the router is not updated. Only restarts and this message appears in red: Error: Unabled to update firmware.
There's one thing that I know will prevent the update - the battery needs to be at least 20% charged. I'm running my M1 without the battery, using just an upgraded charger (Qualcomm QuickCharge 2.0 compatible - providing 2.4A). The M1 fails to update because the OS is looking for 20% battery charge.
If this isn't your problem, I suggest you contact your carrier's technical support team for guidance. The firmware appears to be customised for each country/carrier.
