Arkeil_c
Aug 26, 2020Follower
Mr1100 used as modem?
I was wondering if I can use my MR1100 as a modem and connect it to a Netgear AC1200 for better connection.
icaruspony
Sep 02, 2020Luminary
Pretty much. You put the MR1100 into passthrough mode, disable its DHCP server, and disable Ethernet Standby.
