Aleida71
Jun 07, 2021Aspirant
MR1100 will work for Security camera
Will Nighthawl MR1100 work with Security cameras Please
michaelkenward
Jun 08, 2021Guru - Experienced User
Not enough information for anyone to even guess.
What security camera? There are many models using different technologies.
- Aleida71Jun 08, 2021Aspirant
Sorry didnt realize that it wouldnt work on all cameras.
Cameras TVT and Box TVT. TV screen LG
I am not Tech Savvy so I apprecite all the help I can get.
Thank you Aleida
- michaelkenwardJun 09, 2021Guru - Experienced User
The MR1100 is just a modem/router that connects you to the Internet.
Security cameras can then work in various ways. Some are hard wired using Ethernet. Others can connect with wifi. Then there are those that have a mix of wifi and Ethernet.
The challenge with the MR1100 is getting everything to talk to one small device with just one Ethernet port.
You'll see from the discussions around here that some people need to connect their mobile routers to a separate router that can accept all the stuff they throw at it.
- Aleida71Jun 09, 2021Aspirant
Thank you Michael,
Will see if my Electrician that installed it to have another go.
I am 150 klms from the nearst city and dont have a computer technician.
Thanks again
