BlightedTalon
Feb 26, 2020Star
MR1100 with firmware 12.06.11.00 and just burns through battery
My hotspot recently recieved the 12.06.11.00 update and this update my hot spot just burns through its batter in around 6 hours where I use to get around 12, it has effectively cut its life in half a...
Bluehavana
Feb 27, 2020Aspirant
I Updated the firmware to this version today instantly started having problems. I have my MR1100 hooked to my home router and it had been working great for months. As soon as i did the update I could no longer get an internet connection through my home router. I also tried to roll back the firmware and got the same error code 16.
JohnPeng
Feb 28, 2020NETGEAR Expert
After M1 is updated, please check whether you can connect to M1 WiFi first. After you confirm M1 is working, please power cycle your home router for it to get a new IP address from M1. Hope this helps.
Thanks
- BlightedTalonFeb 28, 2020Star
For those looking for away to downgrade and get past the errorcode 16 I just went back to 12.06.08.00 with the following method be patiant it works takes about 10 to 20 minutes router will reset multiple times but it does work! now the unit shouldn't burn through battery and no longer, and should stay off when charging... go give it a look and a kudo took me a bit of digging but found a working downgrade method...
