Downunder55
Feb 03, 2023Aspirant
MR1100 with No Battery and USB Drive
I have just purchased a preloved MR1100-1TLAUS - V1 hardware It is currently running NTG9X5OC_10.25.01.01 It runs multiple network sims successfully. Have been able to remove the battery...
Downunder55
Feb 04, 2023Aspirant
Update:
A bit of Googling suggests that an External SSD may in fact need additional peak power to the 2.5" drive.
A USB 3.0 Dual Power Cable, 2 x Type A to Micro-B might be the answer to supplement some additional power, will pick one up tomorrow.
- Downunder55Feb 08, 2023Aspirant
Unfortunately that supplementary power cable didn't work, still allows access to the drive and media, but as soon as you start playing media it reboots.
