Downunder55
Feb 03, 2023Aspirant
MR1100 with No Battery and USB Drive
I have just purchased a preloved MR1100-1TLAUS - V1 hardware It is currently running NTG9X5OC_10.25.01.01 It runs multiple network sims successfully. Have been able to remove the battery...
Downunder55
Feb 04, 2023Aspirant
Update:
A bit of Googling suggests that an External SSD may in fact need additional peak power to the 2.5" drive.
A USB 3.0 Dual Power Cable, 2 x Type A to Micro-B might be the answer to supplement some additional power, will pick one up tomorrow.
Downunder55
Feb 08, 2023Aspirant
Unfortunately that supplementary power cable didn't work, still allows access to the drive and media, but as soon as you start playing media it reboots.
