Brian3013's avatar
Brian3013
Follower
Nov 11, 2019
MR1100
Hello,
I own the Nighthawk MR1100 version (MR1100ABS-2A1NAS) it has been working great with and without TS-9 external antennas attached. However today i disconnected my external antennas so that i could bring my MR1100 with me away from home and i noticed the device was not getting any signal. I tried reseting the device via the reset button as well as resetting the device with the web gui and still no luck. I plugged my external antennas back up and i immediatly regained signal and was connected to LTE. Why is my MR1100 not able to get any signal with the internal antennas? I get great signal at my house so its not that i am to far from a tower. If you have any advice please feel free to share as i am completly baffled by this. Thanks!
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Brian3013
    Welcome to NETGEAR Community!
    Please remove the external antenna and check the signal quality using the Diagnostics screen found under Settings > Nighthawk M1 Status > Diagnostics section using values below as reference:
    RSRP – The average power received from a single Reference signal, and Its typical range is around -44dbm (good) to -140dbm(bad).
    RSRQ – Indicates quality of the received signal, and its range is typically -19.5dB(bad) to -3dB (good).
    Blanca
    Community Team
  • I also have faced the same problem, for that I saw a facebook post on how to fix this problem. I did it but it's not working properly.
    Someone, Please help me!!!!!
