Tcormie's avatar
Tcormie
Follower
Aug 17, 2021
Mr1100
Netgear nighthawk mr1100 carriers in Louisiana
  • michaelkenward's avatar
    michaelkenward
    And?
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
    • AyeAyeAye's avatar
      AyeAyeAye
      Apprentice
      There are 139 virtual carriers in the USA
      https://www.mordorintelligence.com/industry-reports/united-states-mobile-virtual-network-operator-mvno-market
      If you buy M1 outright the choice is yours.
      Visible on Verizon gives unlimited 5Mbps hotspot if downloading is your main thing, $40. You can add a Apple Watch unlimited data for $5
      Not sure if a Sim in M1 will be considered hotspotting ?
      On 5G, Visible is capped at 200Mbps so maybe a M5 is better? 5G does not saturate and slow down anywhere like 4G.
      With Party Pay, when you add two lines, Visible knocks the per-line charge down to $35 a month, so you're paying $70 total. Three lines cost $30 each, while four lines can be had for $25. If you need more lines, they're now just $25 each, and you can add an unlimited number of people.
      https://www.visible.com/
