terrygyuffey
Jan 07, 2022Follower
mr1100
i paid att for extra data . how do i activate it.
If you are talking about a mobile phone account, you should talk to your operator.
When it comes to mobile routers, this isn't the best place to ask for help.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - JohnPengNETGEAR Expert
This should be activated on your plan by AT&T on the network side. No need to activate on the device.
Thanks
