AnmolSingh
Jan 10, 2020Follower
MR1100ATT connection with the Extender
Can we connect the MR1100ATT mobile hotspot router with the Extender? And if we can connect then I need to ask whether the connection will be stable or not i.e. Do we need to connect the extender wit...
Blanca_O
Jan 16, 2020NETGEAR Employee Retired
Hi AnmolSingh
Welcome to NETGEAR Community!
If you wish to extend the WiFI coverage of your Nighthawk MR1100 then you can add a WiFi extender to your network.
You may want to configure the MR1100 WiFi range settings: access MR1100 router page, go to Settings > Setup > Wireless > Global Wireless Settings > WiFi range > you can select it either Short, Medium or Long.
Blanca
Community Team
- JohnPengJan 19, 2020NETGEAR Expert
I think the extender connection/reconnection performance is really determined by the exterder itself. You may need to give such setup a try to find a suitable extender to use.
Thanks
