Drail14me
Mar 09, 2021Tutor
MR1100ATT ethernet port not working
I have a MR1100ATT. This Mobile wireless wifi hotspot is my only source of internet. I'm wanting to connect a laptop to it via the ethernet port but it won't work. When I go to the wifimanager to ch...
Blanca_O
Mar 15, 2021NETGEAR Employee Retired
Hi Drail14me
Welcome to NETGEAR Community!
Just want to check if you are using the USB as a charging port for your MR1100. If so, kindly disconnect the USB cable then check if you can go online wired to the MR1100.
Blanca
Community Team
- Drail14meMar 15, 2021Tutor
Thanks for the note Blanca.
It appears that it was a bad port. ATT sent me a new one and it's working fine.
- Drail14meMay 24, 2021Tutor
Blanca_0,
I am not able to get internet through the Ethernet port even with the USB charging plug disconnected.
Also, this is the second MR1100ATT that has had this problem. I was not able to get the Ethernet port on the last one to work so AT&T sent a replacement claiming the old one had a bad Ethernet port. The new one does not work either.
- Blanca_OMay 26, 2021NETGEAR Employee Retired
Hi Drail14me
Just to clarify, the Ethernet port of the replacement unit never worked.
Do you WiFi connection?
Please provide the device SKU (e.g MR1100-2A1NAS) and firmware version.
Blanca
Community Team- Drail14meMay 26, 2021Tutor
Blanca,
The SKU on the replacement is 6421B. The firmware is NTG9X50C_12.05.05.14
The Ethernet port on the original nor the replacement has ever worked. AT&T is sending a third replacement unit.
WiFi connection on the original and replacement works fine.
Dennis
