Drail14me
Mar 09, 2021Tutor
MR1100ATT ethernet port not working
I have a MR1100ATT. This Mobile wireless wifi hotspot is my only source of internet. I'm wanting to connect a laptop to it via the ethernet port but it won't work. When I go to the wifimanager to ch...
Blanca_O
Mar 15, 2021NETGEAR Employee Retired
Hi Drail14me
Welcome to NETGEAR Community!
Just want to check if you are using the USB as a charging port for your MR1100. If so, kindly disconnect the USB cable then check if you can go online wired to the MR1100.
Blanca
Community Team
Drail14me
May 24, 2021Tutor
Blanca_0,
I am not able to get internet through the Ethernet port even with the USB charging plug disconnected.
