Drail14me
Mar 09, 2021Tutor
MR1100ATT ethernet port not working
I have a MR1100ATT. This Mobile wireless wifi hotspot is my only source of internet. I'm wanting to connect a laptop to it via the ethernet port but it won't work. When I go to the wifimanager to ch...
Blanca_O
Mar 15, 2021NETGEAR Employee Retired
Hi Drail14me
Welcome to NETGEAR Community!
Just want to check if you are using the USB as a charging port for your MR1100. If so, kindly disconnect the USB cable then check if you can go online wired to the MR1100.
Blanca
Community Team
Drail14me
May 24, 2021Tutor
Also, this is the second MR1100ATT that has had this problem. I was not able to get the Ethernet port on the last one to work so AT&T sent a replacement claiming the old one had a bad Ethernet port. The new one does not work either.
- Blanca_OMay 26, 2021NETGEAR Employee Retired
Hi Drail14me
Just to clarify, the Ethernet port of the replacement unit never worked.
Do you WiFi connection?
Please provide the device SKU (e.g MR1100-2A1NAS) and firmware version.
Blanca
Community Team- Drail14meMay 26, 2021Tutor
Blanca,
The SKU on the replacement is 6421B. The firmware is NTG9X50C_12.05.05.14
The Ethernet port on the original nor the replacement has ever worked. AT&T is sending a third replacement unit.
WiFi connection on the original and replacement works fine.
Dennis
