Drail14me
Mar 09, 2021Tutor
MR1100ATT ethernet port not working
I have a MR1100ATT. This Mobile wireless wifi hotspot is my only source of internet. I'm wanting to connect a laptop to it via the ethernet port but it won't work. When I go to the wifimanager to ch...
Blanca_O
Jun 09, 2021NETGEAR Employee Retired
Hi Drail14me
There's a 2 minute timer for ethernet port. We shut Ethernet port down after 2 min if not in use to save battery.
You may need to have the ethernet cable in the device during power up. Otherwise the device powers up, wait for 2 mins then shuts down the ethernet port.
Kindly disable Ethernet standby in the Web UI. Go to Settings > Setup > Mobile Router Setup > Ethernet Standby > select Disabled > Apply
Blanca
Community Team
Drail14me
Jun 10, 2021Tutor
Blanca,
Thanks for the note. I have tried changing the Ethernet Standby settings several times. I've also powered on with the ethernet plugged in and with it not plugged in. No luck.
I've spoken with Netgear support a half dozen times. They will not support my device becuase it won't register. They said it won't register because I purchased through AT&T and that I'll have to get support from AT&T.
I spent an hour and a half on the phone yesterday with AT&T with no solution. They told me to call Netgear to which I explained that Netgear told me to contact AT&T. AT&T said they would contact Netgear on my behalf today. We shall see. I don't understand why Netgear won't support one of ther products because of where I purchased it. It's still their product.
- Drail14meJun 22, 2021Tutor
Yes, took about 3 hours to download but I did get the firmware update. However, that did not resolve the issue. I get get a not connected or unplugged notice on my MacBook and on my PC when I connect to the Ethernete port on the MR1100.
- wenmingJun 29, 2021Aspirant
Try power on your MR1100 using a powerbank with 2A output. Then connect though ethernet port.
- Drail14meJul 06, 2021Tutor
Nowhere under "Setup > Mobile Router Setup" is there any options or mention of Tethering. I can't find any options for "Tethering" anywhere in the "Setup" menus.
I have Ethernet Standby disabled.
