Drail14me
Mar 09, 2021Tutor
MR1100ATT ethernet port not working
I have a MR1100ATT. This Mobile wireless wifi hotspot is my only source of internet. I'm wanting to connect a laptop to it via the ethernet port but it won't work. When I go to the wifimanager to ch...
Blanca_O
Jun 22, 2021NETGEAR Employee Retired
Hi Drail14me
I just want to check if you were able to update the firmware to NTG9X50C_12.06.39.00
Blanca
Community Team
Drail14me
Jun 23, 2021Tutor
Yes, took about 3 hours to download but I did get the firmware update. However, that did not resolve the issue. I get get a not connected or unplugged notice on my MacBook and on my PC when I connect to the Ethernete port on the MR1100.
- wenmingJun 30, 2021Aspirant
Try power on your MR1100 using a powerbank with 2A output. Then connect though ethernet port.
- Drail14meJul 06, 2021Tutor
Nowhere under "Setup > Mobile Router Setup" is there any options or mention of Tethering. I can't find any options for "Tethering" anywhere in the "Setup" menus.
I have Ethernet Standby disabled.
