Drail14me
Mar 09, 2021Tutor
MR1100ATT ethernet port not working
I have a MR1100ATT. This Mobile wireless wifi hotspot is my only source of internet. I'm wanting to connect a laptop to it via the ethernet port but it won't work. When I go to the wifimanager to ch...
Drail14me
Jun 23, 2021Tutor
Yes, took about 3 hours to download but I did get the firmware update. However, that did not resolve the issue. I get get a not connected or unplugged notice on my MacBook and on my PC when I connect to the Ethernete port on the MR1100.
Blanca_O
Jul 06, 2021NETGEAR Employee Retired
Hi Drail14me
Kindly access M1 settings page and check the following:
- Go to Setup > Router Setup > under TETHERING section, select Charge Only.
- Go to Setup > Router Setup > Ethernet Standby option, select Disabled.
Blanca
Community Team
- Drail14meJul 06, 2021Tutor
Nowhere under "Setup > Mobile Router Setup" is there any options or mention of Tethering. I can't find any options for "Tethering" anywhere in the "Setup" menus.
I have Ethernet Standby disabled.
