dkozlows's avatar
dkozlows
Follower
Apr 05, 2019
MR1100EUS – Nighthawk M1 Mobile
I plan to purchase MR1100 router - Nighthawk M1 Mobile version MR1100EUS. Is it possible to use the LTE internet access on the RJ45 connector in this equipment (Ethernet tethering) ?
I find this answer :
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Pre-April-Nighthawk-and-band-14-and-46/m-p/1553448
but there is no model MR1100EUS.
  • Hi dkozlows
    Welcome to NETGEAR Community!
    You can connect an Ethernet device to the Ethernet port and you can offload your mobile Internet data. When you are using an Ethernet connection, you can use the USB type C cable and the AC adapter to recharge the mobile router battery.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi dkozlows
    Blanca
    Community Team
