supajo
Jun 08, 2020Follower
MR1100EUS - Firmware
Hi, i have heard that for the MR1100EUS is a new firmware version 12.06.12.00 available. Trying to use the update check from the webinterface nothing happens. When will the download on the supportp...
dabidou
Jun 08, 2020Tutor
Yes, mine updated itself 1 week ago from 12.06.11.00 to 12.06.12.00, I could not prevent it.
PRI goes from 10.03 to 11.01
GUI goes from 4.01.80.00 to 4.01.81.00
Firmware date is 2020/04/26
It updates automatically even if no battery is plugged.
No information at all on what is changed/fixed.
