erichsch
Jul 11, 2020Star
MR1100EUS Firmware V12.06.12.00 please put it in your Downloadcenter
Dear Netgear Admins! This is my 3rd try to get an answer of my question. My Router is not able to install the new Firmware over OTA. Is it possible for Netgear to put the new Firmware in the Do...
Blanca_O
Jul 13, 2020NETGEAR Employee Retired
Hi erichsch
Welcome to NETGEAR Community!
Please describe what happens when you attempt to update the firmware via OTA.
Is there an error message?
What is the current firmware version and PRI version?
Blanca
Community Team
- erichschJul 13, 2020Star
Thank you for answering.
my version is NTG9X50C_12.06.11.00 this Version was only possible to install with a Firmware from your Downloadcenter.
PRI=10.03
When i klick on "Check for Update" it switch to "Checking". Thats all.
Why is it so hard for Netgear to put the Firmware in the Downloadcenter? I dont understand this politics.
P.S.:
I dont like to reset my Router. The new Firmware spend the Router more CA handling. Thats the reason why i need the update.
kind regards
- dabidouJul 13, 2020Tutor
Hello
I could update mine with OTA beginning of June from 12.06.11.00 to 12.06.12.00.
PRI 11.01
Firmware date 2020/04/26
No information at all on what was changed/fixed/added. Did not notice any improvement.
Netgear, is it that difficult to post release notes?
And why is it not available as separate download?
I do not understand Netgear support.
- erichschJul 16, 2020Star
Many users beg Netgear to put Firmware, drivers, etc. into the Downloadcenter. Why they must do this?
Is it so difficult for Netgear to put the latest Software after releasing it automatically in your own Downloadcenter?
i dont understand this logic.
Your Downloadcenter is one of the poorest Downloadcenter i knew.
Who have the responsibility for the Downloadcenter?
I am convinced that the wrong person is doing the job. :-)
