kaledi
Jun 09, 2021Initiate
MR2100 0 days remaining won't reset
I have recently bought a MR2100. No matter what I do, it constantly shows that there are 0 days remaining for the billing start date. I have just gone througha billing cycle i.e. the 9th and it did...
kaledi
So, I removed the EE sim and put in a Vodafone sim and this resolved the issue. Clearly, this must be an issue with EE. Could it be with the APN settings? Some advice here would be valued.
- TSpitzmannJun 12, 2021Guide
I did experience the same problem with a Telekom sim.
I did solve this issue by adding authentication details to the APN configuration.
Yes I think the APN database which NETGEAR is using has got faulty entries (user name, password and authentication type) ;-)
Regards
Tom
