suth
Jan 17, 2023Follower
MR2100 antenna connection query
Hi, I've just bought a Nighthawk M2 for use in our motorhome along with a Poynting Puck 7. The Puck comes with 4 cables and the M2 only has 2 antenna ports.
So, which ones do I connect or how do I converge 4 cables into 2 ports?
Thanks
1 Reply
- JohnPengNETGEAR Expert
Check the antenna specs. Seems it doesn't support the MR2100 mobile hotspot type of devices.
Thanks
