Fritto58's avatar
Fritto58
MR2100-EUS - BUFFERING ON SMART TV
iL ROUTER con LTE WIND, anche due tacche su 5, ha un ottima velocità in DOWNLOAD sempre > 100 Nbps e UPLOAD > di 15Mbps. Non ho problemi con SKY, Netflix, DAZN e ovviamente con il PC, ma con lo SMART TV con app's Video, va spesso in Buffering. Si puo risolvere con qualche modifica di parametro sul Router? Prima con Vodafone FWA con dati di veocità piu bassi in Dowload, questo non accadeva.
Il Router collegato via LAN al TV
Grazie per il supporto.
  • Could you please try connecting your Samrt TV via WiFi and see whether the issue goes away?
    Thanks
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
    Thank you
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Thanks
    • Fritto58's avatar
      Fritto58
      In Wi-Fi buffering goes Away. I do not understand why, buy it works. Il you do not mind please could you explain? In Any case thanks a lot
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        Based on your descriptions, the issue is interoperational issue between the TV app and Ethernet connection. It requires logs to really find out what is the real issue.
        But based my own experiences, most likely the TV app is to blame. I have a smart TV. the built-in app can't access my NAS, but a third party app installed on the same TV can.
        Thanks
