SHANELLI
May 23, 2022Aspirant
Mr2100 HAS NO WIFI
My Mr2100 Router won't find wifi. Has a red cross on the wifi button. Have tried restarting and a factory reset, still the same. Will connect to computer with ethernet cable but no wifi on cell...
Blanca_O
May 30, 2022NETGEAR Employee Retired
Hi SHANELLI,
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR2100-1TLAUS) and firmware version?
Have you tried to access the Web UI and enable WiFi? If so, what happen?
Kindly check if you have set WiFi Standby to Disabled.
Blanca
Community Team
- SHANELLIMay 30, 2022Aspirant
Thanks so much.
Did all the above.
Have since sent in and seems to be a hardware issue.
Have a replacement.
Cheers
