Streetfox
Dec 13, 2022Aspirant
MR2100 INCORRECT BATTERY INSERTED
Hello trusted community. I have a Netgear MR2100, which the battery has failed and will not charge. It works perfectly without the battery installed ie connected straight to the USB port. I purchased...
JohnPeng
Dec 14, 2022NETGEAR Expert
You need to check the battery P/N number printed on the battery label.
The compatible battery for M2 should have the P/N:
308-10077-01
Thanks
John
