Lukasa
Feb 27, 2020Follower
MR2100 internet connection always dropped while falling back to 3G network due to poor 4G signal
Hi, I'm a frequent travller between LA, TX, Japan and Taiwan. I bought the M2 device at Hong Kong around four months ago, and I have MR1100 at the same time. The issue here is my MR2100 route...
JohnPeng
Feb 28, 2020NETGEAR Expert
Sorry for the inconvenience you are experiencing with MR2100. Since the device is European version, I think only LTE band 3 and 7 can be used in North America. That is why you see the device dropping to 3G often.
We are going to release an update in the next couple of weeks for MR2100. It will help to improve the connectivity issue you reported.
Thanks
