BSL81
Oct 25, 2022Tutor
MR2100 locked to provider. how to unlock
Hi im in Aus and i have a MR2100 locked to Telstra (provider) the contract has been cancelled and i want to use it with my new provider but its locked. how can i get it working?
JohnPeng
Oct 29, 2022NETGEAR Expert
You can contact Telstra for the unlock code. They should provide it if the device is already out of contract.
Thanks
- BSL81Oct 29, 2022TutorTurns out it doesnt need an unlock code but there is a service for unlocking as you suggested.
an optus data sim will slot straight in and work straight away. - StacesPlaceJan 03, 2023Aspirant
I have a Netgear Nighthawk MR1100 which I purchased through Telstra a couple of years ago. I now have an unlock code which Telstra have provided so that I can use it with another carrier. However I can not find any instructions on how to apply this unlock code. Can anyone help please.
- W1lliamJan 03, 2023Virtuoso
insert different SIM card, other than Telstra, and login to Web GUI, it will be asking for unlock code
Sorry I'm not sure I understand. By the WebGUI do you mean logging on to the device via WiFi? If so I have done so but there is no prompt for an unlock code.
