BSL81
Oct 25, 2022Tutor
MR2100 locked to provider. how to unlock
Hi im in Aus and i have a MR2100 locked to Telstra (provider) the contract has been cancelled and i want to use it with my new provider but its locked. how can i get it working?
JohnPeng
Oct 29, 2022NETGEAR Expert
You can contact Telstra for the unlock code. They should provide it if the device is already out of contract.
Thanks
StacesPlace
Jan 03, 2023Aspirant
I have a Netgear Nighthawk MR1100 which I purchased through Telstra a couple of years ago. I now have an unlock code which Telstra have provided so that I can use it with another carrier. However I can not find any instructions on how to apply this unlock code. Can anyone help please.
- W1lliamJan 03, 2023Virtuoso
insert different SIM card, other than Telstra, and login to Web GUI, it will be asking for unlock code
- StacesPlaceJan 03, 2023Aspirant
Sorry I'm not sure I understand. By the WebGUI do you mean logging on to the device via WiFi? If so I have done so but there is no prompt for an unlock code.
it can be WiFi, Ethernet or USB, as long as you can login to the device via Web browser.
If you are not getting prompt asking for unlock code, were you able to connect to the Internet via different SIM card?
