cristianmann
Feb 10, 2020Tutor
MR2100 LTE router - the connection is dropping random every day .
Hello I have a new M2 MR2100 lte router. I bought 2 , one for me and one for a friend. The LTE connection is dropping random every day, for few secs and after that it reconnect and working. It is an...
JohnPeng
Feb 11, 2020NETGEAR Expert
Sorry to hear the disconnection issue you are experiencing.
Could you please let me know the device SKU and the carriers you and your friend are using?
Thanks
John
- cristianmannFeb 11, 2020Tutor
Sure,
I am using Orange-Romania and my friend is using Telekom Romania. For me is happening to disconnect from few secs distance for 2-3 times and after that it will work 1-2 hours. After that again disconnect for few times. The device SKU: MR2100-100EUS. I have purchased it now one week ago. Before it I was using a Huawei device, with the same sim and APN settings and it works fine for 2 years , with no disconnect. So the problem is at the devide , not carrier.
When disconnect for few secs the led indicator is RED and after that it is blue again .. - cristianmannFeb 11, 2020Tutor
Hi again,
what i see on the display of the device is that when switching from 4G+ to 4G it is disconnecting.. and after reconnects to 4g+ it is working again. Maybe not this is the problem , but this is what i sow.
- JohnPengFeb 12, 2020NETGEAR Expert
Thanks for the detailed information. Could you please provide the following information for us to check whether the two carriers APNs were set properly in our database.
Carrier Name:
APN:
ICCID: the number printed on the SIM card starting with 89.
I can also set your devices to upgrade to our latest release to see whether the issue will go away. If you would like to help on this, please provide the IMEIs of your two devices. I will let you know when you can upgrade your devices.
Thanks
John
