fedevago's avatar
fedevago
MR2100 new - very slow
I just got a new MR2100.
I put a SIM inside and I found a download speed never higher that 4 Mbps.
The upload is around 10-14 Mbps.
With a cheap ZTE MF971V4 router with the same SIM in the same location the download is around 15 Mbps.
I bought the MR2100 to have high speed as described in many tests I found on Internet.
Maybe I need some special setting?
Thanks. Regards.
  • ArodiD's avatar
    ArodiD
    NETGEAR Expert
    Hi fedevago ,
    Can you please provide the exact model number of your MR2100 and the carrier SIM you are experiencing the slow speeds on?
    Arodi
    • fedevago's avatar
      fedevago
      Hi Arodi,
      please find annexed the image of the label of my router.
      The carrier I am using is WindTre.
      Thanks. Regards.
      Federico
