adrianstanners
Jan 17, 2021Follower
MR2100 Nighthawk GPS Tracking Location
I'm wondering if anyone can advise me whether my MR2100 Night Hawk that I use in my motor home can be used to track it's location if stolen.
michaelkenward
Jan 18, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
You could also check the manual for the device.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
