Transfluxor
Mar 04, 2021Apprentice
MR2100-TLAUS bug fix
Hello, over the past six months that I have this router, I have received 3 updates, but not a single error that I will write about has been fixed. After every update, I did a factory reset. Also, the...
Transfluxor
Mar 10, 2021Apprentice
I will add to my post:
Yesterday, to ensure a little more autonomy, I set the screen time of 30 s instead of 1 min. And today I could not unlock the device. when it wakes up from idle mode, it reacts to buttons only after 35-45 seconds. The screen lights up, I do a swipe up, but because the screen goes out after 30 seconds, this swite is ignored. I had to pull out and reinsert the battery.
Gentlemen from Netgear, how could such an unfinished product be put into production?
How can you release so many firmware for it and not really fix anything?
ArodiD
Mar 10, 2021NETGEAR Expert
Hi There,
Thank you for bringing this to our attention. Our engineers are trying to reproduce this issue. Please keep an eye on your PM's as I may reach out to you with some additional questions on your configurations.
Arodi
- TransfluxorMar 17, 2021Apprentice
Perhaps I have determined in which case WiFi does not work.
Usually I wake up the MR2100 in the morning by touching the power button, in this case, although I have to wait a long time for awakening, everything works fine. But if I do not touch any buttons and the screen and connect the sleeping router to the USB port of the laptop, then after 1-2 minutes it wakes up by itself but Wi-Fi does not work. Shows a red cross at all times. WiFI starts working only after rebooting the MR2100.
